show upm history exec-id
show upm history exec-id number
Description
Displays information about an instance of a UPM profile executed on the switch.
Syntax Description
number Specifies the execution identifier for the event you want to view.
Default
N/A.
Usage Guidelines
To view the execution identifiers for which you can display information, enter the show upm history command.
The following example shows information for the event identified as 8006:
# show upm history exec 8006
UPM Profile: p1
Event:  User Request    , Time run: 2006-10-18 11:56:15
Execution Identifier: 8006      Execution Status: Pass
Execution Information:
1 # enable cli scripting
2 # set var EVENT.NAME USER-REQUEST
3 # set var EVENT.TIME 1161172575
4 # set var EVENT.PROFILE p1
5 # enable por 1:1
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
